License consumption by virtaul machines
  • Jun 18, 2024 1:29 PM UTC
  • 89 views
Forum|alt.badge.img+9
If a VM is being backed-up ( VSA backup ) from 2 different backup-sets using the same storage pool, is there any impact on the license consumed by this VM ? will there be a double ‘charge’ for it - per Front-End ( capacity license ) ?
Best answer by HolowEd
@TNO ,
No, if you are using Commcell Console run a Job Summary report for the 2 subclients and see what the application size is. If using Command Center, run the Backup Job Summary report and look for the same information.
Edward J Holowienka
  • Jun 18, 2024 8:37 PM UTC
@TNO ,
Being you are talking about Capacity, yes there could be the chance that you are seeing it twice; To confirm you would need to check the subclient that is backing up the VM and see what is recorded for it Front End. I would expect you to see the size of the VM counted by each subclient.
Edward J Holowienka
  • Jun 23, 2024 6:36 AM UTC
Thanks @HolowEd
you would need to check the subclient that is backing up the VM and see what is recorded for it Front End -  you mean chargeback report ?
  • Jun 24, 2024 12:44 PM UTC
@TNO ,
Edward J Holowienka
