LTO 6 Tape is showing No data in New tape library.
  • Oct 15, 2024 5:53 AM UTC
  • 103 views
LTO 6 Tape is showing No data in New tape library LTO 9. backup is available on LTO6 tape
Best answer by Abhishek Narulkar
@Bapu You can follow these steps to merge it in the CS
https://documentation.commvault.com/2023e/expert/merging_content_from_cataloged_tapes.html
  • Oct 15, 2024 9:16 AM UTC
https://www.lto.org/lto-generation-compatibility/
LTO-9 drives can read and write to LTO-8 and LTO-9 media only
Are your tape drives LTO-9?
@Bapu This message shown in the pop-up is due to CS not having any job registered against this tape barcode.
If this is LTO6 tape, do you have any library with LTO 6 drive? You can try tape catalog to read the contents of the tape.
  • Oct 16, 2024 11:04 AM UTC
Yes we have LTO7 drive in new library. We did the tape catalog now its showing as catalog media.
