Mountpoint Protection
  • Mar 1, 2024 8:42 AM UTC
  • 45 views
Forum|alt.badge.img+13
i have heared something about mountpoint protection, but i can’t find this option. Can someone help me?
Regards
Dennis
Best answer by Arunkumar P
Hi @Dennis ,
I hope you’re looking to protect the data in the mount paths from ransomware attacks.
If yes, then please do refer the below links.
https://documentation.commvault.com/2023e/expert/ransomware_protection_01.html
https://documentation.commvault.com/2023e/expert/protecting_mount_paths_from_ransomware_02.html
Arunkumar P
Arunkumar P
Forum|alt.badge.img+9
  • Mar 1, 2024 8:46 AM UTC
Hi @Dennis ,
Arunkumar P
