Multiple back up for same VMGroup using same mediagent
  • Aug 1, 2024 11:38 AM UTC
  • 163 views
Forum|alt.badge.img+2
We want to run two backup jobs on a same VMgroup, using two different server plans which are configured to store backups on two different Object stores.
We are also using same media agent; will it cause any issues?
Thanks.
Best answer by Scott Moseman
What is the problem you are trying to solve?  Have backups going to 2 different libraries?  If so, that’s the exact purpose of setting up Aux Copies.
Scott
Scott Moseman
Forum|alt.badge.img+23
How do you plan to run 1 VM Group against 2 Plans?
Scott
  • Aug 2, 2024 6:04 AM UTC
We have 2 different VM Group for same set of VM.
Biswadeb
Scott Moseman
I imagine Full jobs will work fine, but Incr jobs will be an issue.  VMware is not going to be tracking changes (CBT) separately for the 2 VM Groups.  I have not seen this done before, so I don’t know if the Incr jobs will have failures or if they’ll just give you incomplete data.
If you want the data in 2 different storage locations, why not just Aux Copy?
Scott
  • Aug 2, 2024 5:30 PM UTC
Will Aux copy solve our problem?
Just so that you know both targets are cloud storage.
Scott Moseman
Scott
