NDMP backup with storage array added
  • Oct 7, 2024 6:31 AM UTC
  • 39 views
Forum|alt.badge.img+16
we migrated our file server around 30 tb which was backed up using windows server file system agent to netapp FS ,
what will be the recommended way to protect the netapp FS ,
if i add the storage array and taking backup does it increase the storage utilization ? will the dedup work which was taken using with file server agent ,
or ndmp without storage array added will be better
Best answer by Sureshkumar S
Hi Ajal,
Good day!
If the backups are run in the policy associated with same DDB then you will have dedup work
There are 2 ways to protect netapp file server. please refer the below documents
https://documentation.commvault.com/2024e/essential/netapp.html
https://documentation.commvault.com/2024e/expert/getting_started_with_ndmp_agent.html
https://documentation.commvault.com/2023e/expert/data_protection_for_nfs_exports_and_cifs_shares.html
You can go through docs and decide the approach that suits your infrastructure.
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
Hi Ajal,
Good day!
Sureshkumar S
