Need to reset all my backups
  • Jun 26, 2024 3:20 PM UTC
  • 53 views
We are running out of space and need to redesign.  I haven’t used Commvault in some time and forgot how.
Best answer by Abhishek Narulkar
@Robert Dorans If you are using disk library, then you can view the disk library summary to identify what is occupying more space.
https://documentation.commvault.com/2023e/expert/viewing_disk_library_summary.html
You can also check the Data Aging and Forecast report to identify which jobs are about the age.
https://documentation.commvault.com/2023e/expert/data_retention_forecast_and_compliance_report_overview.html
Based on this information you can decide which jobs can be pruned.
what do I need to delete to purge the backups
  • Jun 26, 2024 4:59 PM UTC
First aproach will be to reduce the retention on your policies or plans.
You can also delete the jobs from each copy of your storage policies or plans.
More drastical will be to delete directly the storage polcies or plans defined.
And run the data aging administrative job in all cases.
