Reporting auxcopies without a schedule
  • Sep 28, 2023 9:42 AM UTC
  • 26 views
is there an easy way to find out copies in storage policies that are not scheduled? It is easy to find clients with “No schedule” but this option is not available for auxcopies.
Thank you.,
Thomas
Best answer by Nutan Pawar G
@ThomasG
This report is not exactly what you have asked for.
However, try to use this report to identify storage policies with auxiliary copy jobs that have not run because they were killed, failed to start, or have not run for another reason and see if this meets your requirement
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/135/664/11436
@ThomasG
