Storage Policy Cloud Metallic
  • Jan 31, 2024 8:35 AM UTC
  • 45 views
Carmine Bollettino
Apprentice
I need to set up cloud backup retention according to the following criteria
- the last 7 daily backups
- the last 5 weekly backups
- the last 5 monthly backups (end of month)
- the last 2 yearly backups (year end)
Is it OK the way I think it is set?
I kindly ask for your assistance.
Thanks a lot
Carmine
Best answer by SMD
Hi Carmine,
Yes, you have set it correctly. except for the yearly full backups. We will have to set it as 2X365 if we want to retain 2 yearly full backups at all time.
Suleman
  • Jan 31, 2024 8:57 AM UTC
Hi Carmine,
Suleman
