Tape-Drive-Sharing via iSCSI
  • July 10, 2023
  • 694 views
Hi guys,
has anyone experience with iSCSI-attached tape libraries and the sharing of the drives? It should work, but it is not really documentated and I am concerned about performance, stability and functionality. Even more, if only one network is available for both, regular network traffic and iSCSI connection. Any information/experiences would be apreciated. thanks a lot!
Best answer by Rajiv
Hello @Goesta
I would request you to check the documentation once, it has a lot of information regarding tape drive sharing:
https://documentation.commvault.com/2022e/expert/9778_san_attached_libraries_overview.html
Best,
Rajiv Singal
Rajiv
  • July 10, 2023
Hello @Goesta
Best,
Rajiv Singal
  • July 10, 2023
Hi Rajiv, thank you, and yes regarding SAN you´re right. But I found only one slight remark regarding iSCSI:
https://documentation.commvault.com/2022e/expert/59218_driver_configurations.html
For me that sounds like, yes, it should work, perhaps...:o) The goal is to share a library with 2 LTO-8-drives over a 25 GB network via iSCSI-interfaces… It seems that nobody, even Commvault Germany has any experience with that...
Rajiv
  • July 11, 2023
Hello @Goesta
I am sorry to hear that.
Please let me know if you are looking for assistance in configuring the tape library environment from Commvault’s representative?
Best,
Rajiv Singal
  • July 11, 2023
Hi Rajiv, thank you anyway - I will discuss a PoC with the customer for that. best, Goesta
