Tape library to have LTO8 and LTO9 tapes
  • Dec 3, 2024 11:53 AM UTC
  • 130 views
Forum|alt.badge.img+5
Dears,
I have a question,
In an organization, we plan to replace an MSL6480 (LTO8 tapes) with a new MSL6480 (LTO9 tapes) and decommission the old one once the new one is configured but the need the data on the old tapes.
My question is what I need to do to make the new library read data from LTO8 and LTO9 Tapes successfully?
Thanks for your support.
Best answer by Ledoesp
Please have a look here:
For the new tape library, it will be able to read the LTO8 tapes
https://www.lto.org/es/lto-generation-compatibility/#:~:text=LTO%2D9%20drives%20can%20read,you%20consider%20your%20needs%20today.
Other option is to copy the jobs in LTO8 media to LTO9 media with auxiliary copy if you don’t want to keep the LTO8 media.
  • Dec 3, 2024 4:36 PM UTC
