Tape Slots - ReOrder Sequence
  • Jan 29, 2025 12:42 PM UTC
  • 42 views
YYZ
Apprentice
Hi
Is there a way to have commvault re-order the sequence of tapes in a library
eg move the lowest sequence barcode to slot 1, the next to slot 2 etc
Best answer by Sureshkumar S
Hi ​@YYZ ,
Good day!
Re-orderring the tape has to be done through the specific library management tools
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
Hi ​@YYZ ,
Good day!
Sureshkumar S
