What is difference between secondary blocks and unique blocks in DDB
  • Aug 9, 2024 11:58 AM UTC
  • 139 views
Hello Sam,
The following goes over it in detail:
https://documentation.commvault.com/2023e/expert/optimize_storage_space_using_deduplication.html
But for the short answer, Primary records point to a written chunk of data on your disk.
Secondary records point to a Primary record. One Primary can have multiple secondary pointing to it and this is the % savings. Each of those secondary records are an attempt to write data that was mitigated as it was already on the disk.
Kind regards
Albert Williams
Hello Sam,
Kind regards
Albert Williams
