WORM and Dell Powerscale/Isilon Smartlock
  • September 27, 2023
  • 359 views
just one question:
If Commvault WORM copy with Dell Powerscale/Isilon Smartlock is enabled, will the data be pruned after the retention of the copy has met?
Thank you.
Thomas
Best answer by Daniel Brouwer
Worm Data retention settings
https://documentation.commvault.com/2023/expert/157131_enabling_worm_storage_and_retention_for_disk_libraries.html
Forum|alt.badge.img+5
Hi Daniel,
Thank you very much.
  • October 11, 2023
According to documentation WORM lock time period is the sum of the retention of the storage policy pool copy and the DDB seal frequency. How will this effect the time of pruning (if at all)?
