CommServe move to Azure
  • February 20, 2024
  • 87 views
Forum|alt.badge.img+8
I am planning on moving a CommServe to Azure.
As part of my planning I will make sure that once the CommServe is migrate to Azure it can talk to the Media Agents & Clients on ports 8400-8403 and vice versa. I will also have ports 80 & 443 open so I can connect to the Web Console.
Am I missing again ?
Best answer by HolowEd
atitagain,
Those are correct and should be all that you need. But just in case here is the list of all ports used by Commvault this is if you are using any of these on another machine in the evironment.
https://documentation.commvault.com/2023e/expert/port_requirements_for_commvault.html
Reqards,
Edward J Holowienka
  • February 20, 2024
atitagain,
Reqards,
Edward J Holowienka
