Continuous Replication - Specify Source Node?
  • Nov 25, 2024 6:39 PM UTC
  • 71 views
We need a method to specify source nodes for replication groups.  We keep having issues where the source node changes to a VM that does not have access to the datastore/cluster that the replicated VM lives on.  We’ve been asking for this functionality for a few years now and we’re at a point where we need a workaround or find go find a different solution.
Does anyone else have this issue and can help put pressure on this request?  Anyone have a workaround?
Best answer by Prasanna Kumar TR
​@Zach  - here is the doc page for the same : https://docs.commvault.com/2024e/essential/editing_access_node_of_continuous_replication_pair.html
Hey ​@Zach,
I escalated this to a few folks. For continuous (VAIO) replication, support to customize the access node for source/destination on each replication pair can be modified 11.36. It seems that it is missing in the documentation - that will be fixed.
