default firewall tries to connect through 8403
  • July 20, 2023
  • 828 views
I have quite strange situation, we’ve intalled simpana 9 on an HPUX 11, first we’ve installed the with a firewalled envirnonment and it didnt work (it seems simpana 9 doesn’t like the firewall config)
after that we’ve reintalled the agent with the firewall disabled on the client but the commserve stills tries to connect through the port 8403.
Attaching to beta2rp*beta2rp*8400*8402 using XDR failed. Error:[0xE8090010:{CCvNetwork::Attach_RemoteServiceInternal(1693)} + {CCvNetwork::Attach_RemotePort(1400)} + {CCvNetwork::GetConnection(3272)} + {CSessionConnectionSocket::GetConnection(218)/EventMessage.0x09000010.9:16.(Remote machine [beta2rp]. The socket connect failed. Error returned [-1=Connection failed on spfpt01cmv01 with these errors: 1) Connect failed: Failed to connect fd=3324 to 172.20.192.162:8403: Connection refused; 2) Timed out waiting to be patched through a tunnel]. Check Network Connectivity.)}]
20744 07/20/23 11:22:09 :CVSession attach to Remote Host beta2rp, Remote service FLRPort Failed
20744 Failure reason : Generic Failure
ERROR: CvFwClient::connect(): Connection failed on spfpt01cmv01 with these errors: 1) Connect failed: Failed to connect fd=3472 to 172.20.192.162:8403: Connection refused; 2) Timed out waiting to be patched through a tunnel
at the console there isn’t any firewall configuration for the client.
there is a way to force the default configuration?
Best answer by Rajiv
Hello @Ilitia
We are currently on Commvault 11, I am afraid version 9 is way too old and is not supported anymore.
Are you sure the version is correct? If yes, could you please upgrade your environment accordingly?
https://documentation.commvault.com/v11/essential/2619_platform_release_schedule_and_lifecycles.html
Best,
Rajiv Singal
Rajiv
  • July 20, 2023
Hello @Ilitia
Best,
Rajiv Singal
