Error code 91:16 Restore Full Virtual Machine in Nutanix
  • January 25, 2024
  • 153 views
Carmine Bollettino
Apprentice
Hello, everyone,
I use Nutanix as my hypervisor and am trying to restore a VM from Metallic in the hypervisor.
The job fails for this reason:
Error code: [91:16]
Description: A virtual machine with name [SB-Log] already exists. Please delete this virtual machine manually or select overwrite option and resubmit restore job.
Source: pcnideas2019, Process: vsrst
Is it possible to remedy this error by renaming the VM being restored?
Unfortunately I can't find any option that allows me to do this.
I ask for your support.
Thank you
Carmine
Best answer by Sebastien Merluzzi
HI @Carmine Bollettino ,
You need to choose Out of Place Restore:
https://documentation.commvault.com/2023e/expert/restoring_full_virtual_machines_08.html
For an out-of-place restore, specify parameters for the restore:
  • VM and Disk: This column shows the source virtual machines. Expand a virtual machine to view the disks in that virtual machine.
  • Change VM display name to: Enter a new display name for the virtual machine.
Let me know
Sebastien
Let me know
Sebastien
