Firewall Ports for Hyper-V Backup & Restore
  • Sep 2, 2024 11:53 AM UTC
  • 724 views
Forum|alt.badge.img+2
We want to migrate VMs from Vmware to Hyper-V using Commvault. The Hyper-V will be a cluster with SAN storage to store the Cluster files. The Hyper-V cluster will be hardened with Windows Firewall rules. What are the ports to be allowed for allowing Restore of VM from VMware to Hyper-V and Backups of Hyper-V VMs on Proxy.
Best answer by Damian Andre
Hyper-V relies heavily on WMI - but that should be local communication with the installed agent and the WMI destination. I do not believe we traverse the network to perform WMI queries if you have a Virtual server agent installed on all nodes.
Hello @Kamesh
The following are the port requirements for CV to work in general:
https://documentation.commvault.com/2023e/essential/port_requirements_for_commvault.html
As long as we can talk to your proxy with these there should not be any network issues that i can see you hitting. Just treat it like a brand new Hyper-v client:
https://documentation.commvault.com/2023e/essential/guided_setup_for_hyper_v.html
Kind regards
Albert Williams
  • Sep 6, 2024 5:26 AM UTC
  • Sep 16, 2024 7:43 AM UTC
So, the ports needed to open for Hyper-V standalone or cluster nodes are 443, 902, 8400, 8403? Another question is after the restore of VMs from VMware to Hyper-V. Does the First backup coverts to Full by again copying entire size of each VM after deduplication to Local storage or Cloud storage.
