Guest files restore taking Primary VSA even browsing from the Secondary Copy and Failing
  • Sep 16, 2024 12:56 PM UTC
  • 62 views
Forum|alt.badge.img+5
Hi All,
We have a VM backup with (VMware) VSA Snap. The same job was copied to secondary which was in Azure.
Our VSA was later removed as there is no dependency on it.
We are trying to restore few Guest Files from the VM backup from the secondary copy with Azure Media Agent and Library, but the restore is failing saying that the Old VSA was unable to communicate.
Not sure why it is asking this way, even we are browsing it from Cloud MA which is having VSA installed on it.
Our VM was a Windows Server, Old VSA is Windows and new MA/VSA is Linux.
Any suggestions or idea, why it is taking it even we are giving other MA/VSA?
Thanks in Advance..
Warm Regards,
Sravan Kondeti
Best answer by Sureshkumar S
Hi @backup ,
Thanks for the update
We may need to check the logs to identify the cause
I would request you to raise a support case with all logs to proceed further on this
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
Hi @backup ,
Good day!
Is the old VSA server Is it being removed completely from the commserv console/Virtual pseudo client instance properties or its only decommissioned?
Guest file is performed for windows or linux VM ?
I would suggest you raise a case with CV support to investigate this further.
Sureshkumar S
  • Sep 17, 2024 9:21 AM UTC
Hi @Sureshkumar S ,
Thanks for responding.
It is only acts as a VSA. It is decommissioned and removed from Virtualization Client.
And the Guest File browse we are performing is a Windows machine.
Live mount and browsing are happening with Cloud Media Agent, but while running the restore, it is pointing to old VSA which is already removed.
Sureshkumar S
Hi @backup ,
Sureshkumar S
