How Commvault backup Openshft
  • January 3, 2024
  • 659 views
Forum|alt.badge.img+9
Hello All,
How COmmvault backup openshift Kubernetes cluster? I could not find on the documentation?
What is the logic of openshift backup? What commvault do on openshşift during backup? as I know It creats temprory worker pod?
Best answer by MichaelCapon
Hi @ETO,
With NFS we mount the NFS Share to the Worker Pod to perform the read of data.
The transfer of data from Pod to Access Node is done via the kube-apiserver.
Michael
MichaelCapon
Hello ETO,
For OpenShift, configure as Kubernetes cluster, refer to the documentation here: https://documentation.commvault.com/2023e/essential/protecting_kubernetes_with_commvault.html
Requirements can be found here: https://documentation.commvault.com/2023e/essential/system_requirements_for_kubernetes.html
We leverage an Access Node to manage the backups from the K8s side into Commvault.
We do deploy temporary “Worker Pods” for each Volume to protect, In order to mount the volume/pvc of snap to read the Data and send it to our Access Node. (Machine with Agent installed).
Backup Process is outlined here: https://documentation.commvault.com/2023e/essential/backup_process_for_kubernetes.html
Michael
  • January 4, 2024
Hello Michael
Thank you for answer.
Actually I have read these documents before. We are using nfs for Kubernetes. How sends data to the access nodes. Which protocol is used?
MichaelCapon
  • January 4, 2024
Hi @ETO,
Michael
