Issues with sporadic failed VM Backups via hotadd
  • Jul 4, 2023 8:31 AM UTC
  • 10 replies
  • 939 views
We’re running into a strange issue with hotadd VM backups.
For some VMs we see the error “Failed to download config file” and “Failed to open disk”. This is never for the same VMs over and over again, but sporadic and always for different VMs.
We have two SCSI controllers defined on the Proxy and each controller has a “dummy”/”actual” disk as the first disk. (As advised by VMWare: https://kb.vmware.com/s/article/2075069
Has anyone ever seen this issue? Any idea what might be causing it?
Best answer by Damian Andre
In general I’d not recommend HotAdd for NFS datastores if you can avoid it. Sometimes VMware struggles with locking and you can end up with unresponsive VMs.
Hi @Jeremy ,
Can you confirm that the port assignment is correct?
Can you check our Documentation:
https://documentation.commvault.com/2022e/expert/32048_hotadd_transport_for_vmware.html
Sebastien Merluzzi
  • Jul 4, 2023 10:08 AM UTC
Hi Sebastien,
Thank you for your answer!
I had a look at the VMX file, but it looks fine.
scsi0.pciSlotNumber = "160"
scsi1.pciSlotNumber = "256"
Might we be running to a limit here? Do we need an additional SCSI controller?
Although I’m not sure that might explain the errors we’re seeing.
Rajiv
  • Jul 4, 2023 10:40 AM UTC
Hello @Jeremy
A single SCSI controller can have up to 15 disks attached, with at least one SCSI device node reservation for the virtual machine OS. If you run concurrent backup jobs that include more than 15 disks, you might need to add SCSI controllers to the VSA proxy that is responsible for hot adding disks.
If the current one’s are not meeting your environment, please attempt to increase it and monitor the environment.
Best,
Rajiv Singal
@Jeremy ,
Yes you can add a SCSI and confirm.
Onno van den Berg
Forum|alt.badge.img+24
@Jeremy I assume it worked without problems before, right? Did you make any changes to the environment. Which Commvault version are you running? Which delivery model are you using for the storage towards the hypervisors?
  • Jul 4, 2023 2:19 PM UTC
Hi @Onno van den Berg
Yes, the entire environment was refreshed, so new media agents, libraries and VSA proxies. Unfortunately, I’m not able to say if the issue appeared before the hardware refresh. Either way, we’ll have to find a way to solve this. We might engage Commvault Support. To me the configuration of the proxy looks fine, I implemented the best practices as stated on the documentation website. We’re running 11.28 by the way. We’re using NFS datastores, so we might try and implement NAS transport mode, instead of hotadd, but that something for the near future.
@Jeremy ,
You can follow the Testing HotAdd steps in the doc I sent you and if they work then sure, log a case with Support and we will check.
  • Jul 18, 2023 12:34 PM UTC
  • Jul 19, 2023 9:13 AM UTC
Hi @Damian Andre
Thanks for the info. The VMWare article does seem related, but it talks about unresponsiveness during snapshot removal (and creation) but we’re not having issues with these two actions. The issue occurs specifically during the backup copy process.
For the record, we have a support ticket open for this issue.
  • Jul 27, 2023 7:47 AM UTC
I wanted to provide an update on this topic. Both Commvault Support and VMWare pointed to the article shared by @Damian Andre as a root cause for the issues. They both advised to not use a single VSA proxy for several hosts when using NFSv3 datastores. They proposed the following solutions:
  • Configure a VSA Proxy per host
  • Use NBD
  • Use NFSv4 te mount the datastores to the hosts
