power off VMware VM before backup and boot afterwards
  • Feb 19, 2024 3:43 PM UTC
  • 407 views
I have a VM that has a pass through PCi device configured (GPU).
I need to backup this VM.
As  snapshots cannot be taken and CV agent cannot be installed due to network restrictions, I thought of turning off the VM before backup.
There I have a couple of questions:
Which technology will the pre-script use: ssh to ESXi Host, Rest-API to Vcenter or Powercli from media agent?
Where is the script hosted? On the VSA=mediaagent or on the ESX Host?
Are there any examples available?. I did not find anything on the net.
Thanks for the support
Best answer by Jim P
Hello!  In regards to shutting down and starting the VM, this would need to be a script set up outside of Commvault then this can be added to the subclient performing the backup as a pre and post script. The Script would exist on the VSA Access node. FYI: Support Team does not create scripts.
For further information on running these scripts please review the documentation below.
  • Feb 20, 2024 4:11 PM UTC
  • Feb 20, 2024 4:12 PM UTC
PS: Alternatively you can schedule a task in vCenter to power down the VM for backup window
  • Feb 23, 2024 4:19 PM UTC
Thanks Jim, yes I found the documentation, I was just hoping there would be a sample script somewhere. So I need  script that works from the VSA=media agent.
