Retired VM not deleted automatically after rentention period
  • Oct 11, 2024 11:28 AM UTC
  • 51 views
Hi. New to CV. I was under the impression that VM that have been retired would be deleted after their retention period.
Best answer by Mohamed Ramadan
hello @typer100
I hope you’re doing well!
I recommend reading about Commvault's data lifecycle. In short, after the retention period, there’s an operation called Data Aging, which manages the reten data following the pruning process, known as "physical deletion.
So if you have an issue with this, could you check the Data Retention Forecast Report? Also, make sure you’ve enabled data pruning at the library/storage policy level.
Mohamed Ramadan
Data Protection Specialist
Mohamed Ramadan
Explorer
hello @typer100
Mohamed Ramadan
