VMWare VSA backups and ESXi Lockdown mode
  • January 2, 2024
  • 137 views
Hi there,
Does anyone have experience enabling VMWare ESXi Lockdown Mode (Normal or strict) and how it interacts with CommVault VSA backups for VMWare? Customer has a mix of SAN direct, NBD, and HotAdd (via proxy) backups.
Hello @cmoss
The following goes over what VMware states about the different lockdown modes and who it will impact
https://docs.vmware.com/en/VMware-vSphere/7.0/com.vmware.vsphere.security.doc/GUID-F8F105F7-CF93-46DF-9319-F8991839D265.html
In Commvault when creating the User account we recommend the following:
https://documentation.commvault.com/2023e/expert/configuration_of_vsphere_user_accounts.html
I recommend making sure that the account that is created in the above is included in the exception user list and backups should not be impacted.
Kind regards
Albert Williams
Hello @cmoss
Kind regards
Albert Williams
