VSA proxy add to Vcenter
  • Nov 11, 2025 9:29 AM UTC
  • 94 views
Dears,,
I created a new linux virtual machine and installed the Commvault Virtual Server package on it in order to use it as a VSA Access Node for our vCenter environment. However, the server does not appear as an available Access Node, and I am unable to use it for VMware backups.
Best answer by Sureshkumar S
Hi ​@Fawzi ,
Good day!
Make sure Mono package is properly installed on new linux proxy
Is this VSA proxy from a cloud platform ? If so you need ot use below key
https://documentation.commvault.com/additionalsetting/showallvsaproxies.html
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
  • Nov 12, 2025 3:53 AM UTC
Hi ​@Fawzi ,
Good day!
Sureshkumar S
  • Nov 23, 2025 9:40 AM UTC
thanks.
