@COMMSERVE@ display in CS hostname and CS clientname
  • January 24, 2024
  • 581 views
I have a problem:
 Commcell can not detect the client on the commcell console, i’m test in server enable selinux and unable selinux OK. But this client not OK.
Azure Linux Media Agent | Community (commvault.com)
Best answer by Thin Dinh
Hello @Thin Dinh
As the previous replies suggest, this issue occurs when the install completes but the final step (registering with the CommServe) fails due to a connectivity issue. Is this a new Client or existing that was updated?
Could you check SimCallWrapper.log and see if there are any errors being reported? CvFwd.log should also indicate if there is a connection issue.
Do you have any network rules in place between this Server and the CommServe? Any Proxies or a Gateways involved? Do these machines have multiple NICs and Commvault should be using a specific network?
Thank you,
Collin
Hi Collin, The root cause is selinux in mode enforcing, after i change the mode = permissive it worked
  • January 24, 2024
@Thin Dinh
The Cs hostname is not detected because the client is not registered.
Could you check port status between client and cs for 8400 and 8403
Add CS hostname on the host file and restart the client services once.
  • January 24, 2024
@Thin Dinh
I try, but is not working.
  • January 24, 2024
run the command cvping cshostname -port 8400
MichaelCapon
  • January 24, 2024
Perhaps you could try using the SimCallWrapper to register the client to the CS, Ref: https://documentation.commvault.com/2023e/expert/registering_client_using_command_line.html
Ensure name resolution is working well first here and that the Client can connect to the CS.
Once completed let us know the result.
Michael
Hello @Thin Dinh
Thank you,
Collin
  • January 25, 2024
Hello @Thin Dinh
Thank you,
Collin
