Media marked as appendable automatically not reusable/not full media
  • Feb 18, 2024 6:29 AM UTC
  • 186 views
Hi Team,
We have facing issue in our commvault infra. While running auxillary copy job media marked as appendable its not full , after appendable is not reusable
This appendable media is not full, also tape is getting stuck inside the drive,
if we can reuse this appendable tape without erase the existing data(because we data retention in 5 years)
please share any solution for this issue
 Hello @Adarsh.op
I can see you have raised 4 separate questions for the same topic.
To save you the admin work i will get all but the following closed off.
KInd regards
Albert Williams
 Hello @Adarsh.op
KInd regards
Albert Williams
Correction: This is the link to the active thread:
A
  • Feb 20, 2024 9:35 AM UTC
Hi Williams,
We mistakenly created the topic, how to remove from the topics
could you please suggest how to remove the unwanted topic from my profile
